i have a 650TI BOOST 2gb (EVGA w/ stock cooler). and i followed the chart that slick provides for overclocking GPU.
these are my clocks:
how can i make these better. i dont know anything about overclocking.
Space Journal #1: So Apparently i  was dropped on the moon like i'm a mars rover, in a matter of hours i have found the transformers on the dark side of the moon. Turns out its not that dark since dem robots are filled with lights, i waved hi to the Russians on the space station, turns out all those stories about space finding humans instead of the other way around is true(soviet Russia joke). They threw me some Heineken beer and I've been sitting staring at the people of this forum and earth since.
https://linustechtips.com/topic/220343-graphics-cards-overclocking-help/
is it stable? have you ran any benchmarks also can you go fether
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
find other people with same gpu and see if your are around the same OC. As i recall 650ti is not exactly a excellent overclocker. run 3dmark11 benchmark and try and see if your card is somewhat stable and then compare your result with other people.
move the sliders further up?
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
it is stable. what should i move further, core clock or memory? or both
