Difference between these motherboards?
Go to solution Solved by Shaqo_Wyn,
Best would be the Deluxe or PRO.
Best budget: Z97-A/AR
Differences are insignificant. Looks, SATA ports, other stuff. It's an effective market strategy.
So many freaking Asus Z97 boards whats the difference between them and which one is the best of the bunch?
Would be awesome if you guys could tell me.
Z97-P
Z97-AR
Z97-PRO With WiFi AC (I know about the non Wifi one it's just without wifi, Right??)
Z97M-PLUS
Z97-K
Z97-C
Z97I-PLUS
Z97-A
Z97-DELUXE
So many f*cking boards Asus! Why do you make it so hard to choose a board!
https://linustechtips.com/topic/220174-difference-between-these-motherboards/
now i look at it the naming scheme aint that bad. they use letters which probably stand for something or pretty obvious words. but alas i still dont know what they mean :P
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
Z97-P
Z97-AR
Z97M-PLUS
Z97-K
Z97-C
Z97I-PLUS
Z97-A
Z97-DELUXE
They each have a slightly different feature set and/or layout and/or color scheme.
Get whatevers cheapest and has all the features you need.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Bert & Ernie before squirting spermie.
We can't tell you which one is best for what you need if you don't let us know exactly what you are using it for.
CPU Intel i7 3770K | Motherboard ASUS Z77 Sabertooth | RAM G.Skill Ripjaws Z 16GB(4x 4GB) | GPU ASUS GeForce GTX 680 DirectCU II TOP | Case Thermaltake Overseer | Storage Samsung SSD 500GB 850EVO, WD Caviar Black 1TB | PSU Cooler Master Silent Pro M2 Series 1000W | Display(s) ASUS PB278Q 27", 2x Samsung LS22C45KBW 22" | Cooling Corsair Hydro Series H75 | Keyboard Razer Lycosa | Mouse Razer Lachesis | Sound Dell speakers a525 2.1, Razer Kraken 7.1 | Operating System Windows 7 Professional
