My main question is, how it works? For example, if I have 144mhz monitor & I have let's say 80fps, will screen tearing appear? I mean it depends how much hz monitor has? Or it will be still locked on 60fps?
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/219943-how-does-vsync-work/
If you have a 144Hz monitor, turning Vsync on will not allow the game to render at above 144FPS. If your graphics card can only run the game at 80FPS, you'll still get 80FPS unless you reduce refresh rate to 60Hz
"Rawr XD"
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014749
Most 144hz monitors can be turned down to 100 and 120hz.
Vsync makes the GPU wait until the monitor is ready to refresh--vsycn just limits your fps to the max your monitor is capable of.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014753
Exactly what @Aniallation said, the FPS will not be allowed to go over 144, just so that there isn't 2/3 frames being displayed in one refresh of the display.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014777
I know it limits the max my monitor is capable of, but I asked something else: What happens if for ex. I'm playing Crysis 3 with the fps of 80 on 144mhz monitor. Will it have screen tearing if I enable vsync?
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014810
I know that. I asked something else.
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014816
no
Tearing occurs because while the monitor is grabbing the frame from the graphics card, the gpu has already replaced the frame....Basically the monitor sees the first half of the first frame, and by the time it gets to the second half, the gpu has already replaced that frame with a new one.
PSU Tier List | CoC
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014826
no
Thx
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014829
It will be the same as Vsync being off, cause Vsync is basically just a frame rate limiter. So no.
"Rawr XD"
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014831
So there's no need of vsync if fps is below the monitor refresh rate. Thx
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014841
If you run 80 FPS on a 144 Hz display, they will go out of sync and you will get tearing. If you enable vsync you'd be pegged at 72 Hz (as long as the computer can maintain 80 FPS, or really any FPS from 72 to 143) which would eliminate tearing because they would be in sync (obviously), with the monitor displaying each rendered frame twice.
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014905
One says it won't have tearing, another says it will. I'm confused now  :huh:
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3014922
If you get a stable 80FPS, best thing to do would be to set refresh rate at 72Hz and run Vsync.
I don't notice screen tearing, so I don't use Vsync myself
"Rawr XD"
https://linustechtips.com/topic/219943-how-does-vsync-work/#findComment-3015080
