I've looked at many videos surrounding the bit fenix connect red 7cm led strip each one seems to have more of an orange glow than a red, i was wondering if anyone has these or has seen these in person and can give me their opinion.
I was looking to have white led's at the top of my case and red towards the bottom as i have many more red aspects in the top than in the bottom that the white would more clearly highlight.
If people think these led's do have more of an orange glow any recomendations for a darker red ones?
https://linustechtips.com/topic/219623-bitfenix-led-red/
I had them in my old build. Perfectly red.
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3010422
Ah thanks alot man, i'm going to be using an obsidian 350d with white at the top and red at the bottom what are your thoughts on it, think it will look alright or?
white LEDs top and Red bottom?
Well white really never looks like white. It just brightens up the components in the top part of the case. I have never seen someone mix it with a color, but I don't think it would look particularly good. I have white in my current build:
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3010726
quick PS
I still have my RED strip. If you want i can install it somewhere in my case. Just tell me where exactly ;)
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3010803
How is your red done there as it looks really nice and from the top are you just using the light from the cooler ?
you mean in my last build? I had it taped to the top part of the side panel. The fan is a Bitfenix Spectre LED. the red LED front fan doesn't affect the inside of the case.
The Alchemys are really bright at 12V. This was a single 36cm strip.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011497
quick PS
The bottom of the case shining up?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011532
got a white strip under the case :)
I was PSing it as if the strip was inside.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011539
I meant your red strip :P
I'm curious to know what dual colors would look like.
PSU Tier List | CoC
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011559
what red strip? the one in the first case?
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011605
Ah nice so is the white at the top a white led or is it spectre led's from fans?
I posted too many pictured. from now on quote the post with the picture please :D
I assume you mean my photoshopped version. The top one is a white Alchemy strip, roughly 12" like the bottom one.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011633
PSU Tier List | CoC
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011660
so hold the phone. You are not OP but you still want me to install it? :P
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011726
haha, yes :P
I've been thinking about adding a blue LED to my build but im not sure how it would look...I currently have a white LED strip in it, but I feel like something's missing.
Note: I re arranged the LED strip, now it just runs down the side of the drive cages since it refused to stick to the top. The picture also makes it look quite a bit bluer than it actually is.
PSU Tier List | CoC
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011763
haha, yes :P
hold on then, I will have to reroute my fan cables
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3011831
this will take longer than expected. after about 1.5 hours I still don't have it at the original brightness. This may be because the case is black inside now, and the other one was unpainted. I did some cable modding to get it on a molex but for some reason that doesn't work.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3012739
haha, yes :P
okay so 3 cables and 1 finger had to die for these pictures. Here you go!
post-21525-0-23657200-1411336588_thumb.j
post-21525-0-36784800-1411336602_thumb.j
post-21525-0-73157100-1411336608_thumb.j
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3012941
Welp, still not sure :unsure:
Thanks anyway
PSU Tier List | CoC
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3012963
Thanks anyway
personally I don't like it unless the majority of your components are already the color that you want the LED in.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3013131
Well, my whole rig is black and blue: the picture makes it look quite a bit more blue than it actually is. I might try a blue underglow from behind the board.
PSU Tier List | CoC
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3013136
This is truly perfect for me think i'm gonna commit and get the white and red led's largely to mask the green pcb at the bottom and powersupply colours and the white to be able to highlight components.
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3013334
Thank you @LukaP for giving all the info to vT so he could get his leds to work
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3013423
Thank you @tmcclelland455 for helping vT
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/219623-bitfenix-led-red/#findComment-3013574
