Oh...that type of leak..(I totally thought of >LEEK<) erm..you should probably remove the block & re-fit a air heatsink temporarily over your cpu socket. Then test the cpu-block by ramping up the water flow for a couple hours & see if there's any water leakage.. If not rma it.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/219063-i-found-a-leak/#findComment-3003523
unlikely that he has warranty on his 900D build.
I meant warranty on the cooler.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/219063-i-found-a-leak/#findComment-3003526
  1. disassemble system.
  2. put motherboard in bag of rice (protect the cpu socket)
  3. remove after 1-2 days.
  4. put cpu block, ram and the gpu back in.
  5. Check if board POSTs.
  6. RMA block.
  7. wait for RMA return
  8. rebuild system
(take this opportunity to upgrade if you want to)
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/219063-i-found-a-leak/#findComment-3003674
  6. RMA block.
  8. rebuild system
Rice is the savior of electronics!
Because he had a hard drive.
https://linustechtips.com/topic/219063-i-found-a-leak/#findComment-3003754
I personally use silica gel sachets. But most people only have rice. ;)
https://linustechtips.com/topic/219063-i-found-a-leak/#findComment-3004407
