I was planning on using a 660 ti in my rig but this is only 100 dollars more with better performance should i get this or a different card i want to go nvidia for my gpu
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/21887-choosing-my-gpu/
What are you trying to say?
should i get a 770 or not
https://linustechtips.com/topic/21887-choosing-my-gpu/#findComment-272073
770 forsure is better than 660ti. a 680 is already better than 660ti. Just depend on your budget, if i'm you and got the budget for 770 i will step towards to 770 too.
But i dont know your situation too, example like are you having budget for this upgrade? Want some loading speed (SSD) or anything else then it will be a different story.
My 2013 First Build
Processor : Intel i7 3930K | Motherboard : Asus Rampage IV GENE | RAM : 2x Corsair Vengeance 1600Mhz 2x4GB Kit (Mix color black and red) | Graphics : Asus GTX 680 Direct CU II OC | SSD : Intel 520 Series 120GB | Cooler : Corsair H100i | PSU : Corsair AX760 | Chassis : Corsair Obsidian 650D | Mouse : Razer Mamba 4G Edition | Keyboard : Razer BlackWidow Ultimate 2013
https://linustechtips.com/topic/21887-choosing-my-gpu/#findComment-272156
it all depends on your CPU if you have a kind of low end cpu then i would go the 660ti but if you have a high end cpu then i would go the 770 if the budget fits
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/21887-choosing-my-gpu/#findComment-272203
+1 and what are your specs of your build?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/21887-choosing-my-gpu/#findComment-277807
A gtx 770 would be twice as faster than the gtx 660 ti. The decision is up to you.
This is so so wrong.  :lol:
Anyway, GTX670 price should be dropping right now, maybe you can get that instead. It is the closest to 680/770 but cost much less.  ;)
https://linustechtips.com/topic/21887-choosing-my-gpu/#findComment-278561
770 would be much better then 660ti... If you have the budget for it go for it :-)
CPU: AMD FX 8120 @4.5Ghz - CPU cooler: Cooler Master Nepton 240M Watercooling - Mobo: Asus M5A97Pro - GPU: Sapphire Radeon R9 280X Vapor-X @ 1200Mhz - Memory: Kingston Hyper X 16GBs DDR3 - Storage: Kingston SSD & Seagate Baracude HDD - PSU: Cooler Master V850W PSU- Case: Cooler Master Cosmost II
-- Build Log old PC (HAF XB): 'the Cube': http://linustechtips.com/main/topic/36288-the-cube-cooler-master-haf-xb/ --
https://linustechtips.com/topic/21887-choosing-my-gpu/#findComment-280431
