My step dad just gave my his old gaming comp but the only screen i got dosnt work and i got no money to buy a new one. all im looking to do is set up a 24/7 server in the comp is there any program i can install on my laptop that lets me use my desktop without getting any thing on my desktop first cause there is no way i can do any thing on my desktop without a screen and i dont have a screen XD
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/21795-need-some-help-please/
I don't think so. But perhaps there is a solution.
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269164
If your laptop supports some kind of video-in input then you could connect your desktop to your laptop by a cable. VGA, DVI, HDMI. Check if your laptop supports video-in.
Edit: I doubt your laptop has that. Maybe you can get some kind of VGA/DVI to Composite to connect it to a TV.
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269173
How many actually do?
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269178
sadly not it only has VGA/HDMI out
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269179
Then there's almost nothing you can do. Can't use Teamspeak..because well...that requires a working monitor to install it and get it set up..which of course would defeat the purpose of installing it anyways since you would have a working screen.
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269186
Not many at all. :P
:P
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269197
well thats a darn shame so close to spent all day taking it apart cleening it and geting it all to work
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269204
can i use a ethernet cord from my laptop to the desktop some how? lol
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269218
You would need access to the computer to set it up.
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269221
well i got $20 XD from my birthday but not sure that will buy me a screen
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269223
Found something that still works on ebay for $30
"Fully tested, Working OK! Includes power cord and VGA cable."
http://www.ebay.com/itm/15-LCD-Monitor-/151053855690?pt=Computer_Monitors&hash=item232b82ebca
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269261
Great feedback too.
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269265
lol i only have $20 in cash XD but i will see if my TV has a DVI port i only think it has HDMI tho
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269353
http://www.amazon.com/HDMI-Adapter-Plated-Connector-Female/dp/B000FUVNX8
OR
http://www.amazon.com/DVI-HDMI-Cable-6ft-Male-Male/dp/B0002CZHN6/ref=pd_sim_e_2
Mystery is the source of all true science.
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269358
nope no DVI in the tv XD
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-269374
oh ok well i can try that
https://linustechtips.com/topic/21795-need-some-help-please/#findComment-281558
