What is the 'SIX Axis Control' feature on my LG 22MP65 monitor?
Solved by Geekazoid,
Hello LTT Forum,
http://www.lg.com/uk/monitors/lg-22MP65HQ
SIX Axis Control is listed under Technical Specifications>Special Features.
Thanks in advance.
Six Axis Control actually allows you to adjust, not just the Red, Green and Blue colours of the monitor, but also Cyan, Magenta and Yellow. It's sometimes referred to as "RGBCMY adjustment". I hope that clears things up for you. I know this because I've used an LG IPS monitor which had that capability/option.
