They should be as the size of the cpu hasnt changed, i highly doubt intel would change the way of mounting.
Listen if you care.
https://linustechtips.com/topic/21736-1150-cpu-cooler/#findComment-271396
1150 will have the same mounting holes as 1156 and 1155, so most current CPU coolers on those sockets will work with Haswell chips on 1150.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/21736-1150-cpu-cooler/#findComment-275803
if it fits on 1156/55 it will fit on 1150
CPU: i7 4770k | GPU: Sapphire 290 Tri-X OC | RAM: Corsair Vengeance LP 2x8GB | MTB: GA-Z87X-UD5HCOOLER: Noctua NH-D14 | PSU: Corsair 760i | CASE: Corsair 550D | DISPLAY:  BenQ XL2420TE
Firestrike scores - Graphics: 10781 Physics: 9448 Combined: 4289
"Nvidia, Fuck you" - Linus Torvald
https://linustechtips.com/topic/21736-1150-cpu-cooler/#findComment-290428
According to Intel, 1150 has the same mounting as 1155/1156 so coolers compatible with those sockets will be compatible with 1150.
1155 brackets are compatible
Sorry I didn't understand that. Does 1155/1156 coolers fit on 1150?
https://linustechtips.com/topic/21736-1150-cpu-cooler/#findComment-290463
no.. no it doesnt...  :P
https://linustechtips.com/topic/21736-1150-cpu-cooler/#findComment-290504
Yes, all 1155 and 1156 coolers will fit on 1150.
https://linustechtips.com/topic/21736-1150-cpu-cooler/#findComment-291203
they will all fit but reference ur cpus tdp to the cooler to make sure you have adaquite cooling
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
https://linustechtips.com/topic/21736-1150-cpu-cooler/#findComment-291266
