Looking to upgrade my case, Rosewill Blackhawk. I already replaced the front panel audio and it's still giving me problems. The thing is that I utilize the sonic sound stage/sonic studio/headphone amplification from my Maximus VII which is through the front panel audio only.
I prefer top mounted I/O,usb ports, power (but not a deal breaker), 2-3 front intakes, 1 bottom intake, rear and top exhaust, and I do utilize an ODD.
I have 4 cases so far that I am considering.
In order of least expensive:
Fractal Design Arc Midi R2
Corsair 450D
Corsair Air 540
Corsair 780T
If you have any other suggestions for a high air flow case please let me know
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
https://linustechtips.com/topic/217321-high-air-flow-needed/
You should check out the Silverstone Raven and Fortress lines. They have some really good setups that allow for direct air flow over the motherboard.
ITX Build: CPUIntel i7 6700K MoboAsus Maximus Impact VIII | MemoryCorsair Dominator Platinum 16gb GPU: EVGA GeForce 980 Ti Hybrid | PSU: Corsair AX1200i | StorageSamsung 850 Evo 1tb SSD, WD Red 4tb HDD EnclosurePhanteks Evolv ITX (white) | Cooling: Corsair H100i | Case Fans: Noctua Industrial PPC PWM NF-F12 and NF-A14
ATX Build (in progress): CPUIntel i7 5960X MoboAsus Strix X99 | MemoryCorsair Dominator Platinum 32gb GPU: TBD | PSU: Corsair HX1000i | Storage: Samsung 950 M.2 512gb, Samsung 850 Pro 1tb SSD, WD Red 4tb HDD, WD Blue 750gb EnclosurePhanteks Evolv ATX Tempered Glass (graphite) | Cooling: Corsair H110i Case Fans: Noctua Industrial PPC PWM NF-A14
https://linustechtips.com/topic/217321-high-air-flow-needed/#findComment-2981044
This
Or enthoo pro
https://linustechtips.com/topic/217321-high-air-flow-needed/#findComment-2981059
Air 540 is hard to beat. Not only does it have good airflow but the cable management is so ridiculously easy it isn't even funny.
Corsair Air540 is ball to the wall amazing for airflow, 3 front intake, 2 top intake, all noctua fans will blow your case clean :D
2 top exhaust^ not intake. Why on earth would you have those as intake? you'd be shoving hot air from the cpu down towards the GPU
Dubs are better than subs
https://linustechtips.com/topic/217321-high-air-flow-needed/#findComment-2981388
