I just got a Asus Direct CU 2 780 and just wanted to make sure. I come from a Laptop as you can see down below. and the gpuu temps on it was alot different then Desktop i know.
ok i was just wondering what is a good temp for the card to run when i installed the ASUS Tweek it was at 79C temp target. and i did overclock it some but did not set the core Voltage up at all  and was playing some crysis 3 witch pins the GPU usage at 99% and the temps got to 79 - 80 when i was playing is that still fine? of should i try to lower it?
the card idles at 30 - 35C
Needs Update
https://linustechtips.com/topic/217307-gpu-temps/
Dude these cards are made to last.  Anywhere under 90-95 degrees C is fine for safe operation, and the card will throttle on its own if it gets too hot. A lot of people think that somehow getting higher than 80-ish turns a modern desktop GPU into butter, it won't. They're not phat PS3 GPUs with crappy solder material.
Seeing as you've OC'd the card and it still runs at 80 during Crysis 3 shows how good the cooling is. My 780 Ti runs at about the same temps.
https://linustechtips.com/topic/217307-gpu-temps/#findComment-2980860
