Well i'm building a budget gaming rig under 700$ mainly, and since it's my first time building i would love the opinions of other on how i can improve it!
CPU: AMD FX-8320 3.5GHz 8-Core Processor
Motherboard: ASRock 970 EXTREME4 ATX AM3+ Motherboard
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Drive
Video Card: EVGA GeForce GTX 660 2GB Video Card
Case: NZXT Source 210 (Black) ATX Mid Tower Case
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Update: Forgot to add i have RAM already from my current pc, which is 1 Crucial Ballistix Sport 8GB DDR3-1333
https://linustechtips.com/topic/217293-opinions-on-build/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($179.99 @ Newegg)
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard ($74.99 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($72.00 @ Newegg)
Storage: Intel 520 Series Cherryville 120GB 2.5" Solid State Drive ($64.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($53.98 @ OutletPC)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card ($199.99 @ Newegg)
Case: BitFenix Merc Beta (Black) ATX Mid Tower Case ($19.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($29.99 @ NCIX US)
Total: $695.92
Generated by PCPartPicker 2014-09-17 23:48 EDT-0400
what were you trying to ask? do you already have the parts? if not try this
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/217293-opinions-on-build/#findComment-2979435
Try an R7 265 GPU instead
and windows 8
An R7 265 would be less powerful (though possibly less expensive.)
If he has the $170+ for a 660, why not an R9 270?
https://linustechtips.com/topic/217293-opinions-on-build/#findComment-2979439
don't know if you need a os
CPU: AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($82.98 @ OutletPC)
Motherboard: Gigabyte GA-F2A55M-S1 Micro ATX FM2+ Motherboard  ($34.69 @ Newegg)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory  ($69.99 @ SuperBiiz)
Video Card: PowerColor Radeon R9 280 3GB TurboDuo Video Card  ($181.10 @ Newegg)
Case: Rosewill FBM-02 MicroATX Mini Tower Case  ($22.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $664.34
Generated by PCPartPicker 2014-09-17 23:54 EDT-0400
https://linustechtips.com/topic/217293-opinions-on-build/#findComment-2979464
Total: $695.92
Yea sorry was kinda unclear about it, but i'll certainly take a look at this. Thanks!
And Micro Center has a 660 for 150$ atm so would the extra $ be worth it?
https://linustechtips.com/topic/217293-opinions-on-build/#findComment-2979479
