So im building my first computer and i wanna know are these parts enought to play different games with? My budget is around 700€ (im from finland) and im buying all parts from verkkokauppa.com
Amd fx6300
Cooler mastet elite 430 case
G skill aegis 4gb
Kingston hyperx fury 120gp
Asus m5a97 evo motherboard
Xfx core edition 550w
Windows 8.1
Asus DRW-24F1ST/BLK/G/AS 24x DVD+/-RW
Asus GTX750TI-PH-2GD5 GTX 750 Ti 2048 MB
The total of this is about 680€
I already have mouse keybord, and display.
https://linustechtips.com/topic/216932-help-needed/
I would say ditch the SSD to get an R9 280, that will be much more satisfying. Also upgrade to 8GB of RAM.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/216932-help-needed/#findComment-2973934
What about the 770?Is also a very good choice
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/216932-help-needed/#findComment-2973945
2GB of VRAM, ew. The 3GB is much better on the R9 280
https://linustechtips.com/topic/216932-help-needed/#findComment-2973953
As far as i remember core clock speeds and the stability of the card are more important.I may be wrong...just saying and beside i don't think he will need 3 gb unless he is playing at high res
https://linustechtips.com/topic/216932-help-needed/#findComment-2973979
my usage is damn near always on 100% when I play and I play on 1080p.
https://linustechtips.com/topic/216932-help-needed/#findComment-2973999
