Hyper Threading help
Go to solution Solved by Deletive,
It should already be enable. If not it's in the bio, I believe in advanced settings under ai tweaker.
Download and install the allcpumeter windows desktop gadget. It is a handy little tool to have. Shows ram too. There are other desktop gadgets for your GPU and network traffic as well.
http://addgadgets.com/all_cpu_meter/ (If it shows 8 cores then HT is enabled)
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/216653-hyper-threading-help/#findComment-2969556
You can go to run and write "dxdiag" and see how  many cores you had !!
But the most easy way and trusted way is look up in motherboard :D
And yes thanks,;)
https://linustechtips.com/topic/216653-hyper-threading-help/#findComment-2969598
And yes thanks, ;)
Of course this isn't the proper method of checking but if your interested HT and how your system manages resources then these gadgets are well handy. CPU/RAM/GPU/Network stats constantly on your desktop but never getting in the way. I use them all the time.
post-8262-0-95340400-1410957329_thumb.jp
https://linustechtips.com/topic/216653-hyper-threading-help/#findComment-2973185
  • 2 weeks later...
What gadgets are those? DL link?
https://linustechtips.com/topic/216653-hyper-threading-help/#findComment-3061263
http://addgadgets.com/gpu_meter/
http://addgadgets.com/network_meter/
Although looking for these gadgets through windows store, I did find that Microsoft has discontinued "Windows Gadgets" due to some security update. Not sure what that means for these gadgets.
Gadgets are no longer available on our website because the Windows Sidebar platform in Windows 7 and Windows Vista has serious vulnerabilities. Microsoft has retired the feature in newer releases of Windows. Gadgets could be exploited to harm your computer, access your computer's files, show you objectionable content, or change their behavior at any time. An attacker could even use a gadget to take complete control of your PC. If you're concerned about the safety of gadgets you’ve downloaded, find out more about gadgets and steps you can take to protect your PC.
http://windows.microsoft.com/en-US/windows/gadgets
https://linustechtips.com/topic/216653-hyper-threading-help/#findComment-3062590
