Either your GPU is dying or the drivers need re-installing/updating
CPU: i7 8700k Motherboard: MSI Z370 Krait Gaming RAM: 4x 8GB Corsair Vengeance Pro (2 white, 2 black) GPU: MSI RTX 2070 Armor Case: Corsair Crystal 570x White HDD: 2x 2TB Seagate Barracuda 7200rpm Sata 3 SSD: 240GB Corsair Force 3 + 500GB Samsung 970 Evo Cooling: Corsair Hydro Series™ H150i PSU: Corsair RM750i OS: Windows 10 Pro 64-Bit
Mouse: Logitech G600 Keyboard: Corsair K95 RGB Cherry MX Brown Monitor: Samsung S24C570L 1080p 23.6" + AOC AGON 240Hz 1080p Sound: HyperX Cloud Headset Black/Red + Logitech Z213 Speakers 2.1
https://linustechtips.com/topic/216447-borderlands-2-red-mesh/#findComment-2966086
Or a simple reload of the game
https://linustechtips.com/topic/216447-borderlands-2-red-mesh/#findComment-2966089
i'm running on intel hd 4600, it runs the game fine, around 30-50fps, just started it today though and it's like this. Every other game is fine though.
reloaded the game a few times
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/216447-borderlands-2-red-mesh/#findComment-2966092
Definitely looks like a dying GPU but try reinstalling drivers and see if that helps.
Cheers.
I fixed the problem, apparently the intel hd graphics panel was setting the games anisotropic filtering, I can run the game perfectly fine if i set the option to any value in game, but if the control panel has anything to do with it then that is what happens. Thank god it wasn't the igpu.
Thanks for all the responses and help guys.
https://linustechtips.com/topic/216447-borderlands-2-red-mesh/#findComment-2967094
 phew, good to know. Enjoy your game :)
https://linustechtips.com/topic/216447-borderlands-2-red-mesh/#findComment-2970637
