I heard that there's alot of issues of these mobos.
ASUS M5A97 R2.0
ASUS M5A97 LE R2.0
I also heard of BIOS issues and auto-downclocking the CPU to 1.4ghz.
I'm quite concerned about me getting this mobo and regret getting it.
And if so, What MoBo should I buy (budget side)?
Oh and, AM3+
https://linustechtips.com/topic/216444-well-i-need-help/
ASUS M5A97 R2.0
ASUS M5A97 LE R2.0
It is auto-downclocking it when there is no need for such ghz speed???
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/216444-well-i-need-help/#findComment-2966017
Somebody PM'd me that you shouldn't get it.
And I googled ASUS M5A97 LE R2.0 issues.
I found alot of crap.
you can find alot of crap with every mobo.
For that pricepoint the m5 is the best. sorry.
https://linustechtips.com/topic/216444-well-i-need-help/#findComment-2966036
If you already have it and you're not having these issues, keep it. If you specifically google any motherboards name and then add the word "problem", you're always going to find a lot of crap. That goes for any product, even the ones that are generally regarded as "very good" or "the best". For instance, try googling "noctua problem".
https://linustechtips.com/topic/216444-well-i-need-help/#findComment-2966061
Holy fuck, are you reading my mind?
Because I just did that and you are probably right.
Every mobo has issues.
https://linustechtips.com/topic/216444-well-i-need-help/#findComment-2966069
Are you sure...?
Sure? well no but I know that many ppl have gotten the m5 and had no problem.
https://linustechtips.com/topic/216444-well-i-need-help/#findComment-2966267
