Dat 4gb 770 tho. You should change it to an r9 290 ;)
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/216388-building-d/#findComment-2965304
here you go use the quote button if you want my help
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($264.00 @ Centre Com)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00 @ Mwave Australia)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  ($178.00 @ CPL Online)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($79.00 @ CPL Online)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($65.00 @ CPL Online)
Video Card: MSI Radeon R9 290 4GB TWIN FROZR Video Card  ($449.00 @ PCCaseGear)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($158.00 @ CPL Online)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($107.00 @ CPL Online)
Monitor: BenQ XL2411T 144Hz 24.0" Monitor  ($369.00 @ CPL Online)
Total: $1911.00
Generated by PCPartPicker 2014-09-16 23:22 EST+1000
Specs
https://linustechtips.com/topic/216388-building-d/#findComment-2965310
i fixed it :D
Specs
https://linustechtips.com/topic/216388-building-d/#findComment-2965315
Total: $1911.00
http://gpuboss.com/gpus/MSI-Radeon-R9-290-vs-GIGABYTE-GeForce-GTX-770
https://linustechtips.com/topic/216388-building-d/#findComment-2965433
gpu boss is unreliable, the 290 is on par with the 780 and smashes the 770 any day look up some benchmarks on it
Specs
https://linustechtips.com/topic/216388-building-d/#findComment-2965447
