I'm planning on upgrading to a 4790k with H100i cooler. But when I googled that combination I found some problems regarding temps and stuff. So I thought I'd ask you guys here :D Any of you have experience with this?
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/215751-h100i-problems/
the H100i will kick your H55's ass.
Yea true that, but with a 4790k? :)
https://linustechtips.com/topic/215751-h100i-problems/#findComment-2955901
The H100i has a lot of problems with mounting and it is not guaranteed to work out of the box without additional modifications.  Get either the H105, or Cooler Master Seidon 240M if you are looking at 240mm AIOs.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/215751-h100i-problems/#findComment-2957457
Or that super boss NZXT x61 that linus used in the Razer PC build?
https://linustechtips.com/topic/215751-h100i-problems/#findComment-2957463
That is a 280mm AIO.  Another solid option, just make sure it will fit in your case.
If you live in the U.S. the cooler master seidon can be had for $70.
https://linustechtips.com/topic/215751-h100i-problems/#findComment-2957473
Yea, the top of an H440 has 140mm fan mountings.
Negative, I'm from EU
https://linustechtips.com/topic/215751-h100i-problems/#findComment-2957487
If your motherboard and case have enough clearance for a thicker radiator, I would recommend the h105. It has better performance and a better mounting solution so you get lower temps.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/215751-h100i-problems/#findComment-2958047
No complaints with my Water 3.0 Extreme (240mm Asetek AIO). Mounting was easy and the included monitoring software is nice. Would recommend. I got it for $50 on sale but, temps are fantastic.
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/215751-h100i-problems/#findComment-2958202
