Need help with a decision
Go to solution Solved by AlwaysFSX,
Nicely done!  :3
Thanks :D
Will the i3 run bf4 smoothly? (i had problems with bf3 and a dual core cpu).
Because it has hyperthreading it'll run a lot better than a Pentium or the like, and Intel's single core performance will make it exceptional compared to a 750k.
*NOTE Higher resolution = worse performance than 1080p
Battlefield-4-benchmark-2560-x-1440-Ultr
So I have 2 builds here. The first one is amd based and the second one is intel based. I want to play games such as Battle field 4, Dota 2, Counter strike, and older fps such as modern warfare 2. I do intend on overclocking either of these builds i just want to know which will get me better performance in these games.
http://pcpartpicker.com/user/Darkshadow303/saved/LTn9TW
http://pcpartpicker.com/user/Darkshadow303/saved/hycgXL
https://linustechtips.com/topic/215305-need-help-with-a-decision/
Quad core will help you at newer games (especially in Bf4) and R9 270X is more powerfull than the gtx 750ti.The Amd build looks better.
Definitely AMD. 750K and i3 are about on par in terms of gaming but the 750K is unlocked with a 212 EVO for possible overclocking, and 270X is noticeably better then 750 Ti.
Get a better motherboard though. One with VRM heatsinks
"Rawr XD"
Bam, even better option.
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($110.99 @ NCIX US)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($84.98 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($72.00 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.99 @ Amazon)
Video Card: Sapphire Radeon R9 270 2GB Dual-X Video Card  ($159.99 @ Newegg)
Case: Corsair SPEC-02 ATX Mid Tower Case  ($59.99 @ Amazon)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.98 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($86.99 @ NCIX US)
Monitor: Acer G227HQLbi 60Hz 21.5" Monitor  ($109.99 @ Newegg)
Total: $798.89
Generated by PCPartPicker 2014-09-14 13:10 EDT-0400
Total: $798.89
Nicely done!  :3
Because he had a hard drive.
Total: $798.89
Nicely done!  :3
Thanks :D
