Y510p issues
Solved by spenser_l,
Before you go buying a new wireless card, I would suggest making sure that your drivers are updated. Others who have run into similar sounding issues found a solution when they updated their wireless card drivers. If you have another computer to download them and use a flash drive to put it on your laptop try that. Or if you can plug in your laptop via ethernet cable.
Good luck.
