Help with watercooling
Go to solution Solved by Ghost,
You've been amazing Ghost. Thank you for all you help. I'm now a bit more confident on what I am doing.
Good luck!
Would anyone be able to help me with water cooling my computer.
Parts that I have chosen:
Reservoir:
Bitspower Water Tank Z-Multi 250 ICE Black Reservoir
Pump:
XSPC D5 Vario Pump with Front Cover
Tubing
PrimoChill PrimoFlex Advanced LRT Tubing Clear 1/2ID 3/4OD 10ft
Collant
EK Ekoolant Blood Red Premix 1000mL Coolant
Quick disconnect fitting
Koolance QDC No-Spill Compression Male QD4-M13X19
480mm radiator
Coolgate Copper Tube 480mm Radiator
360mm radiator:
XSPC AX360 Radiator Black
Cpu waterblock
EK Supremacy Acetal + Nickel CPU Waterblock
Mosfet cooler
  • EK-FB ASUS M5E - Acetal+Nickel
Thanks Guys!!!
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/21482-help-with-watercooling/
What all are you cooling? cpu,Gpu,ram,chipset,mosfets and what have you? and what is the budget?
What size rads do you want? How many do you want?
What kind of res do you want?
we need all the info
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-260015
What you need to do before you do anything is read the two stickies at the top of this forum section: the FAQ and the 101.
Then pick the parts out yourself and we can go from there and guide you further as to whether parts you picked were good or bad.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-260017
I'll be cooling the CPU and Mosfets.
Mosfet cooler: http://www.ekwb.com/shop/blocks/motherboard-blocks/full-board-blocks/ek-fb-kit-asus-m5e-acetal-nickel.html
Cpu cooler: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_878_879&products_id=20490
The sky is the limit on budget just anything between $1000
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-260031
Well i would do what ghost said first and then there are more people that could help a lot more
:wacko:
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-260033
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-271432
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-271572
What you need to do is make a bullet pointed list of your parts. Otherwise I am all over the place trying to find your components. Having everything in one place, not just a shopping cart means people reading this thread in the future when that shopping cart is deleted for example can still see your parts.
Also make a diagram of your loop, its important to visualize your loop.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-276222
My list has been updated on the top of the page.
Thank you Ghost.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-276699
Thank you Ghost.
Still need that diagram.
To do this simply grab a 2D side on snap of your case. (Just type your case name into google images and scroll down a bit till you find one, it should be there.) Then go to a photo editing program and simply put rectangles where you would like to place your radiators, blocks, reservoirs, pumps and tubing. For blocks use blue, for radiators use red and anything else use grey and for tubing use orange/brown lines with an arrow to point out the intended flow direction of your loop. There is no need to put fans in. This forum has an upload function or you can use an image sharing site and embed the picture into your post. This is an example of this from my personal loop: http://i.imgur.com/MynbfCp.jpg
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-276713
79126508.pngNot  actually sure how well this loop would be.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-276888
Why don't you utilize the massive amount of space int he bottom compartment for that radiator?
You can also route tube int he back plate int he 900D. Just make sure you don't cross any wires in the back plate.
Try again.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-276927
Try again.
Thanks, that's a great idea. Maybe a another  360?
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-276984
Thanks a great idea. Maybe a another  360?
That's what most people do with the 900D, with the fittings towards the back of the case at the top.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-277001
Revised version put another 360 in the bottom: The darker red means it's behind the case.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-277080
That looks great, now for the parts what do you guys think?
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-277385
All your parts are good. Just remember to get the female part of the QDC and also get a couple of liters of coolant.
I also recommend a pump top for the D5; any top is fine, its just so you can use your own fittings for it.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-277413
I think the last problem I'll have is the different fittings. I think I'v chosen completely different fittings
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-277499
Link me to your choice.
I may not answer today because I need to sleep. I'll answer in the morning if someone else don't by then. Quote me in your reply so I get notified.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-277533
Are all G1/4 compression fittings the same?
Not sure if this fitting: http://www.ekwb.com/shop/accessories/fittings/compression-fittings/for-12mm-7-16-id-tubing/ek-csq-fitting-12-16mm-black.html
Will work with this tubing: http://www.pccasegear.com/index.php?main_page=product_info&products_id=21946
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-278377
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-279326
No they aren't. The two you picked aren't compatible.
If you look at the dimensions of the tubing where it says 1/2 3/4. Your fitting needs to have the same dimensions. The one you picked was 7/16 5/8.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-279582
O.k that's fixed. I had to add another 1/3 to 1/4 extender.
Also another question.
As you provided me with a alternative route.
You see where I have highlighted with a purple box. Wouldn't the tube be going over the graphics cards? How would this look good/bad.
Last thing what is your opinion on colored coolant?  Red coolant would be good, but if it's going to clog up I'll change to colored tubing.
https://linustechtips.com/topic/21482-help-with-watercooling/#findComment-279691
