PC Won't Power Up?
Go to solution Solved by dhkatz,
Finally! I built my PC - but it won't power on? Every cable is plugged in, PSU switch is set to on, power switch cable (And the other small cables) are plugged in correctly... Now what?
Feel free to ask questions, I'll try my best to answer them.
EDIT: Which cable is the 8 Pin? I have an EVGA 850W G2
The 8-pin cable looks as it sounds. It is 8 pins
Also this is where your CPU power goes:
Also make sure any other power cables NOT on the motherboard are plugged in, like GPU if you have one
https://linustechtips.com/topic/214801-pc-wont-power-up/
Yes they are, problem is I don't know where the CPU power slot is. Is it Power slot #2? (Top left)
CPU power is a 4pin or a 8 pin near the cpu socket
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/214801-pc-wont-power-up/#findComment-2939538
It should be on the top of the mobo.
https://linustechtips.com/topic/214801-pc-wont-power-up/#findComment-2939540
They are 4 pins in a square, split into 2 each. (Total of 8) So I believe I've done it correctly. I used the mobo connectors extension for easier use/to plug in. Is that fine? Or can I just plug them without the extensions?
What mobo do you have?
MSI Z97 Gaming 5
https://linustechtips.com/topic/214801-pc-wont-power-up/#findComment-2939547
https://linustechtips.com/topic/214801-pc-wont-power-up/#findComment-2939761
