I need a battery bank to keep in my backpack. It needs to be 15000mah or more and preferable be <$50(USD). Any recommendations?
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/214392-battery-bank/
I have no idea but amazon could be your dilema search enquiry buddy.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=15000mah+battery+bank
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933185
Yeah I just have no idea which brands are good and which ones aren't.
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933202
I'll help you with that :) I'll edit this post with a couple decent picks.
What do you get out of them standard;
  1. Other than the battery size (15000mah)
  2. size/weight being fairly close (1:TeckNet & 2:anker options have nearly identical size & weight, where as option 3:Gembonics is more bulky & slightly heavier)
  3. Dual usb ports (5v/2a + 5v/1a)
  4. Tecknet & anker have an 18 month warranty where as Gembonics has 12months. No hassle.
The included cables are quite bitchy imo but I'd choose either the Tecknet or anker <--has quite a number of good 4/5 star reviews.
Difference in price is somewhat negligible $30-$40 dollars
Edited by wng_kingsley7
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933211
Thanks!
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933245
@Worth updated
Much appreciated man. Thanks a million
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933396
It's okay :) & your welcome good sir. Have a nice day.
Ps you might need to source your own cables for the battery bank(s).
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933416
I intend to source them and I'm probably gonna go with the gembonics because it looks like the texture matches my phone
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933445
Before you do try to look about if they have any bad reviews. Reading the good ones is fine but bad reviews can give you a little bit more insight into the products overall feedback.
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933463
It seems like they're mostly good. I'm looking for reviews not on amazon right now though
https://linustechtips.com/topic/214392-battery-bank/#findComment-2933495
