So im moving my old watercooling parts to a new case along with a new motherboard. I bought Primo Chill Advanced LRT and obviously comes with a system prep. What exactly does it do and should I bother with the trouble of letting it run in my system and draining it just to immediately fill it again?
https://linustechtips.com/topic/213381-primochill-system-prep/
Don't use that system prep. It will make you're tubing all foggy. If you do a quick Google search, you will know what I mean.
http://www.overclock.net/t/1199158/plasticizer-problems-discussion-gallery/2550#post_19796530
You must "Quote" to get my attention​.
 ~IBIubbleTea - 20/07/2014
https://linustechtips.com/topic/213381-primochill-system-prep/#findComment-2910961
I made the mistake of using System Prep and found out the hard way of the tubes clouding. It could have been my fault, I don't know, but I will not use it again. I will just use distilled water, flush until clean and fill the system up again.
I7-4790K OC @ 4.7, Asus Maximus VII Hero, 16gb 2133hz Corsair Vengence, 780 GTX SC (2), 250gb Samsung 840 SSD (2), Phanteks Luxe Pro Chassis, EVGA Supernova P2 1200W,MCP655-PWM pump with Bitspower fittings and upgrade kit, 360, 240 EK Radiators, all other watercooling is EK products
https://linustechtips.com/topic/213381-primochill-system-prep/#findComment-2911511
