Does the monitor/tv react to the pc in any way? This could be the issue.
Well here's what i would go through (you might have done some of there):
1.Check all your wiring, it can be just a minor connector not fully plugged in. Definetely make sure you check your display output (hdmi, dvi, whatever you use). And check the video card power cables too.
2.See if all components are installed correctly, maybe your video card isn't properly plugged in
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
https://linustechtips.com/topic/213333-big-problem-help/#findComment-2909508
Click the Clear CMOS button
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/213333-big-problem-help/#findComment-2909543
but where is the clear cmos button on a msi gaming 5 mobo?
Msi has a video about how to clear cmos on their channel, might help:
https://linustechtips.com/topic/213333-big-problem-help/#findComment-2909799
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/213333-big-problem-help/#findComment-2910087
