So here i am with another new build, this time is based on the new BitFenix Neos, for which i thank BitFenix for sending me one.
This mod is based on rally cars, in this case it's a Lancia Delta ECV, which never saw the light because of the Group S being deleted even before presenting it to the people. So i'm going to paint the whole case Red as the Lancia, doing a window on the side panel, a little spoiler and a reproduction of the bumper. Not so much on this build to do manually. I'll later add some Martini's decals to match with the paint.
Here are some photos before the actual modding:
Here it is the side panel cutted:
I've managed to do a cut resembling to the actual window of the car..
Here it is for now, today i'm going to paint it!
What do you think?
Edit: I've called it ECC because the original ECV means experimental composite vehicle but this is not a vehicle so it's experimental composite case!
https://linustechtips.com/topic/213101-project-ecc/
Looking good! Also, first paragraph says eco, tile says etc...
And you smell cut wrong and put cutted. Right before the last sentence lol
Srry for the grammar naziness
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
https://linustechtips.com/topic/213101-project-ecc/#findComment-2897976
