I have troubleshooted so many things in my PC. I figured out that is has to be the GPU because, I have, changed RAM, PSU, removed all unneeded cards (e.g. Ethernet card), then I changed the GPU to an old one I have laying around and it didn't turn off.
(The warranty is not expired, but I want to try get some help before I send it for maybe no reason.)
https://linustechtips.com/topic/213044-r9-290-makes-pc-shutdown-while-on-load/
Whats your Power supply? you should probably replace it if it's isn't a quality brand or check the 6/8 pins. (or dual 8 pins whichever is uses)
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
Update drivers
It may be your R9 290 drawing to much power. How many Watts is your PSU/ it's rating.
Also do you have any Win Error logs or IDs?
^ If you don't get any errors it's probably something to do with the Power supply because it'll just shut down.
This.
PSU is most likely suspect. Some PSUs might say that they are, for example, 550W yet the amperage on the +12v rail will be considerably less.
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
I would say the psu is the problem in this system.
I got exactly the same problem in my build. Under load my 780 needed too much power and the system shut down after a few minutes without any errors.
I changed the psu and the problem was solved.
So go on, find another psu (don't have to buy one, just borrow) and test your system with the "new" one. If the problem still appears, I would freak out ;) or just check my gpu temps :P
Good luck with solving your problem :)
BTW: my old psu was also a 700W one
I currently am running a 700w Cougar semi modular PSU. But my cousin has the same GPU and he doesn't have this issue.
Exactly which Cougar PSU? Also, the PCI-E power cables you're using, are they connected to the same port or different ones?
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
