Need DvD Drive help Please.
Go to solution Solved by Jlryan,
So to let me clarify:
You have a DVD Writer in your computer that won't write to blank DVD's, but your laptop will write to them perfectly fine.
Your DVD Writer in your computer will only write to DVD's if they have been initialized or written to by your Laptop first.
Sounds like a buggy DVD Writer, What's the manufacturer and model number? Some manufacturers provide firmware updates.
Also just to be sure in case it's not the DVD Writer itself, try a different burning application, I recommend: Ashampoo Burning Studio FREE
Another note to take: Some writers are funny with different manufacturer of blank discs, I get the best results from Traxdata/Ritek if you can find them where you live.
Sorry, hadn't noticed the model number in the OP.
The Sony CRX310EE is not a DVD Writer, only a DVD Reader and CD Writer. Meaning it can only write to 700MB Blank CD's.
Hello my DvD Drive can only read disc that have data on them and when i use my laptop and burn anything onto the same disc that it wouldnt detect .. It detects it and then i can add data to it.. Might it be my driver or maybe another driver is messing with it ?
I have tried the delete of upper and lower files and uninstall the driver and reset computer.
I am running windows 8.1 and the drive is a Sony CRX310EE ATA
https://linustechtips.com/topic/213020-need-dvd-drive-help-please/
So essentially what you're saying is that your drive can only read and not write?
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
A new DVD burner is only like $20, so its not the end of the world.
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
