Hi guys,
Looking at helping a friend build a new rig soon. He's already got a keyboard and mouse and will most likely be using his TV as a monitor through HDMI. He wants the case to be as small as possible so I was thinking about using the Coolermaster Elite 110.
He'll be using the computer to play WoW and Diablo 3. also, he has hard drives (3.5 inch mechanical) already so don't worry about that.
Thanks
Asus MAXIMUS VII Gene 2 x 8GB G.Skill 16GB 1600 Mhz Intel 4670k @ 4.3 Ghz Corsair H100i w/ stock fans EVGA GTX 770 SC Intel 750 Series SSD 240GB, Samsung 840 SSD 240GB WD Caviar Green 2TB Seasonic X-650 V3 2 x 140 mm Noctua A14 PPC, 120mm LED Corsair AF120
https://linustechtips.com/topic/212907-aud650ish-itx-build/
Hi guys,
Thanks
Here. I haven't optimized it yet.
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($78.00 @ CPL Online)
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($164.00 @ CPL Online)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  ($95.00 @ Centre Com)
Video Card: Gigabyte GeForce GTX 750 Ti 2GB WINDFORCE Video Card  ($174.00 @ CPL Online)
Total: $699.00
Generated by PCPartPicker 2014-09-11 11:03 EST+1000
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891273
way over because prices suck but hows this?
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($201.00 @ CPL Online)
Motherboard: Asus H97I-PLUS Mini ITX LGA1150 Motherboard  ($129.00 @ Mwave Australia)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($62.00 @ Centre Com)
Video Card: Asus Radeon R9 280 3GB DirectCU II Video Card  ($245.00 @ CPL Online)
Case: BitFenix Prodigy (White) Mini ITX Tower Case  ($77.00 @ CPL Online)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($114.21 @ Mwave Australia)
Total: $925.21
Generated by PCPartPicker 2014-09-11 10:55 EST+1000
Specs
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891294
CPU Cooler: Cooler Master Hyper 412 Slim 58.4 CFM Sleeve Bearing CPU Cooler  ($55.00 @ CPL Online)
Case: Cooler Master Elite 110 Mini ITX Tower Case  ($47.00 @ CPL Online)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($85.00 @ CPL Online)
Total: $698.00
Generated by PCPartPicker 2014-09-11 10:59 EST+1000
Hey, thanks man. He has a wireless dongle thing already so I think a wireless Ac board isn't needed
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($97.00 @ Centre Com)
Total: $925.21
Thats a great build if he had the money to spend on it. Unfortunately he doesn't have that much to spend =/
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891346
Have a look at this one;
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=319472&action=wish_lists
CPU: Intel Core i3 4350 $145.00
Mobo: MSI B85I M-ITX Mobo $109.00
RAM: Kingston Hyper X Fury 1600MHz Black $99.00
GPU: Gigabyte GeForce GTX 750Ti Black Edition 2GB $179.00
Case: Coolermaster Elite 120 $49.00
PSU: Corsair CX-430 Modular 80+ Bronze PSU $69.00
Total $650
"Since the Internet is almost diametrically opposed to the notion of Quality Control, in recent years it's been a lot easier to just assume everything's s**t until it can prove itself otherwise".  Ben "Yahtzee" Croshaw (2008)
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891350
Total $650
Do you reckon it's worth it trying to fit an SSD into that price bracket?
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891374
If you want to fit an SSD into it i've had to change the CPU.  And it's a tad more expensive.
CPU: Intel Pentium Anniversary Edition G3258 $79.00
CPU Cooler: Noctua NH-L9i Low Profile CPU Cooler $55.00
SSD: Kinkston SSDNow V300 60GB $59.00
TOTAL: $698
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891407
TOTAL: $698
http://au.pcpartpicker.com/p/CHx9nQ is this ok? Or should I try and convince him to go for that Gigabyte 750ti black edition? What's the performance difference between the 260x and the 750ti?
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891432
That looks fine.
There's pretty much no difference between the 260X and 750Ti as far as i'm aware, go with what is cheapest.
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891472
That looks fine.
Right. Ok thanks.
https://linustechtips.com/topic/212907-aud650ish-itx-build/#findComment-2891982
