So I have a graphics card budget of about $150-180$. The more money I can save the better. I've been planning to get the 270 or 270x, but I can't seem to find any that match my color scheme of blue/black.
The sapphire vapor-x is one I found, I like the end of it but it looks like it just has a blue sticker running across the center. I would rather have an actual blue plastic or metal piece.
Also the 7870 Ice-Q but I find it looks disgusting
Ones i found not sold by regular vendors and therefor can't buy:
660ti power edition
7870 Hawk
7870 GhZ edition
Can anyone suggest a card? In the end I may have to choose a plain black one.
"We hold these truths to be self evident, that all men are created equal, that they are endowed by their creator with certain unalienable rights"
https://linustechtips.com/topic/212635-gpu-help/
Gigabyte windforce and plastidip
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/212635-gpu-help/#findComment-2887869
Preferably something that won't void my warranty ;)
Then Windforce only most likely
https://linustechtips.com/topic/212635-gpu-help/#findComment-2888011
If you can splurge $10 more, get this R9 280 for $189
http://pcpartpicker.com/part/sapphire-video-card-100373l
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/212635-gpu-help/#findComment-2888047
^^^agreed if you can go for the 280
It isn't Blue-Black :/
i guess if i can't find a good card and i have to get a card that's a bland black/grey color though that is a good option.
https://linustechtips.com/topic/212635-gpu-help/#findComment-2889378
Well, all you will see with that card is black from the side. It'll be faster than a 270x also. But, it's up to you.
https://linustechtips.com/topic/212635-gpu-help/#findComment-2889564
I have the Bitfenix Prodigy. the cooler on the GPU is literally ALL i will see ;) that's why i'm worried about it.
https://linustechtips.com/topic/212635-gpu-help/#findComment-2889576
Ah, well go to PC part picker and find something that looks nice!
https://linustechtips.com/topic/212635-gpu-help/#findComment-2889623
