Hello, this is the first time I am writing in forum, so I'm not sure how to get started. I apologize if I write something wrong, I'm Portuguese. So here goes, I'm trying to build a gaming PC (my first one) and I'm not sure what I should buy. Wanted to spend about €2000 (if I'm not mistaken about $2500), but wanted your opinion on my choices, whether to change something or in some cases to help me pick one  :D. Thanks!
COMPONENTS
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master Nepton 280L 122.5 CFM Liquid CPU Cooler
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard
Memory: Corsair Vengeance 16GB (4 x 4GB) DDR3-1866 Memory
Storage SSD: Samsung 840 EVO 250GB 2.5" Solid State Drive
Storage HD: I do not know what to choose  :(
Video Card: MSI Radeon R9 280X 3GB TWIN FROZR Video Card or EVGA GeForce GTX 770 2GB Video Card
Case: Corsair Vengeance C70 (Black) ATX Mid Tower Case
Power Supply: Corsair 860W 80+ Platinum Certified Fully-Modular ATX Power Supply
PERIPHERALS
Mice: Mad Catz R.A.T.7 Gaming Mouse (already bought)
Keyboard: I do not know what to choose  :( but I already have one that is not bad (and I can not find mechanical keyboards for sale)
Sound System: GXT 38 ULTIMATE BASS 2.1 SPEAKER SET
Monitor: I  do not even know how to choose  :P
https://linustechtips.com/topic/212437-gaming-pc-build-help/
Cheaper motherboard + better GPU is the way to go.
You can go down to Msi z97 gaming 5 and buy a R9 290 instead of 280x.
You also don't need more than 8gb of RAM.
Anyone who has a sister hates the fact that his sister isn't Kasugano Sora.
Anyone who does not have a sister hates the fact that Kasugano Sora isn't his sister.
I'm not insulting anyone; I'm just being condescending. There is a difference, you see...
https://linustechtips.com/topic/212437-gaming-pc-build-help/#findComment-2884823
ROG boards are overpriced in my opinion, a MSI or Gigabyte Gaming 5 motherboard will be enough, 8gb of ram is enough for gaming, take out the r9 280x and switch to a r9 290, consider a S340 as for the case but the only downside is that it doesn't have 5.25 drive bays, a WD Blue or Seagate Barracuda 1TB hdd will do just fine, everything else looks great.
https://linustechtips.com/topic/212437-gaming-pc-build-help/#findComment-2884875
Well you don't need a platinum psu and the c70 is a bad case. For a hdd I would go with a wd black 2tb or if thats to much a wd blue 1tb
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/212437-gaming-pc-build-help/#findComment-2884908
My hard drive has never failed me, but I've heard people have problems with em: Seagate Barracuda 1TB
As far as the Motherboard goes, that one is extremely pricey if you're not planning anything like extreme overclocking or possibly LN2 (judging from your other components)
Also keep in mind other small accessories like thermal paste, case accsessories, and the most expensive of the bunch: Case fans
I personally wouldn't pick that case, but hey, its just my opinion
My Nighthawk MX8 is great and on sale goes for ~100$, but with youe budget, you could probably squeeze-in a Corsair RGB for the asthetics
2000$ is a huge budget compared to my other builds (1.5% higher) so be sure to spend the money carefully, you could possibly get custom watercooling w/ some cheaper components if you want. Good Luck!
https://linustechtips.com/topic/212437-gaming-pc-build-help/#findComment-2922450
