Hopefully this is the right section.
So I brought my laptop over to my friends and was playing Diablo 3 with him and he was getting disconnected a lot and I never got disconnected at all, we were both wired into the router.  What do you guys think could be causing him to get disconnected all the time?
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/211902-disconnection-problems/
You pulling the cable ;)
just kidding
Is his ethernet adapter working all right?
And does he get disconnected when he's the only one plugged into the router?
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/211902-disconnection-problems/#findComment-2876116
just kidding
I have no idea, how would you go about testing if the adapter is working fine?
Yes he said he gets d/c when hes by himself as well (already made sure it wasn't conflicting ip address).
https://linustechtips.com/topic/211902-disconnection-problems/#findComment-2876128
update motherboard LAN drivers
https://linustechtips.com/topic/211902-disconnection-problems/#findComment-2876152
uninstall and reinstall the lan drivers
also when using ethernet, tell him to disable wireless (if he has wireless) because that can be an issue sometimes
https://linustechtips.com/topic/211902-disconnection-problems/#findComment-2876169
