I'm looking for a stubby flash drive for my shittop. Having a stubby flash drive makes it harder to bend it and it doesn't stick out far. Do you guys recommend any? So far I have come up with this: http://www.amazon.com/Leef-Surge-Profile-PrimeGrade-Memory/dp/B00L1CN56C/ref=sr_1_36?s=pc&ie=UTF8&qid=1410118559&sr=1-36
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/211283-best-tiny-stubby-flash-drive/
aesthetically, they don't look the best but they are ok
Thinkgeek used to sell really cool looking ones but have since taken them down.  I don't remember what they were called. :/
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
You might be referring to this maybe? http://www.thinkgeek.com/product/a6d9/
precisely. thanks.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
The problem with the stubby USB drives is that depending on the physical access to the port it may be near impossible to remove, the first two listed are those  that can be hard to remove, but are very hard to break off accidentally.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
What about an sd card ?
Surly your laptop has sd port.
Or you can buy a regualr sized flash drive and mount it internally. Its doable, if you know your way around soldering iron.
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
How the hell did they fit 32GB in something that is smaller than the port itself?
Die stacking. They can easily stack up to 16 dies (which are usually 8-16GB in size) on one another.
If its possible to make a 128GB mSD card, it sure hell is possible to make a bigger flash drive that size.
