Only one dust filter for the power supply.
CPU: Intel Core i5-4670K @ 4.4GHz CPU Cooler: Noctua NH-D14 GPU: Sapphire R9 290 Tri-X OC Motherboard: Asus Z87-Plus RAM: Corsair Vengeance 8GB DDR3-1600 SSD: Samsung EVO 840 120GB HDD: Western Digital 1TB Blue PSU: Corsair RM1000 Case: NZXT Phantom 630
https://linustechtips.com/topic/211077-nzxt-410/#findComment-2864992
there's also a filter on the front. none on the top though.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/211077-nzxt-410/#findComment-2865004
there are also filter on the front. none on the top though.
It's not really much of a dust filter though.
https://linustechtips.com/topic/211077-nzxt-410/#findComment-2865017
what do you mean? there's an actual filter like the PSU filter. you need to remove the front cover to see it. it is also held by a plastic frame with screws if i remember correctly.
https://linustechtips.com/topic/211077-nzxt-410/#findComment-2865021
It's not good tho, lots of dust goes through
https://linustechtips.com/topic/211077-nzxt-410/#findComment-2867611
I have the 410. The dust filter in the front sucks, but the case is worth it.
Too plasticity. I say get a different case
https://linustechtips.com/topic/211077-nzxt-410/#findComment-2867786
yeah. it was terrible cleaning it. i would've chosen a different case if i had the chance.
https://linustechtips.com/topic/211077-nzxt-410/#findComment-2872055
I velcroed carbon filters to the front of mine, works like a charm
https://linustechtips.com/topic/211077-nzxt-410/#findComment-2873986
