I built my computer a few months back and it has a 4670K with a asus z87k motherboard and a gigabyte 770 4gb card and 8gb vengeance RAM.
I am thinking about buying another 770 and want some suggestions on which board should i buy as the one i currently have doesn't support SLI. My price range for motherboard is about 200$. Just to give you guys the idea of prices in my country, the gigabyte GTX 770 4gb oc is ~500$ at the moment.
also the power supply i have is corsair gs700. Will it be able to run two 770s or do i have to buy a bigger PSU as well. I would also welcome suggestions on any other parts you think i should upgrade down the line to remove bottlenecks and get the max out of everything.
I would really appreciate your input and thoughts on this matter
https://linustechtips.com/topic/210953-need-help-with-upgrading-my-pc/
It'll run on a 700watt probably a little close. I'd say a Msi gaming 5/7 motherboard.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
You will not have to go for a new PSU. If you don't want to spend a lot on the motherboard, the MSI Z97 G55 SLI and Gigabyte GA-Z97-SLI are good choices.
OK, I have been doing a little research for the past few days. I personally have no experience with MSI, but the internet says that MSI is not good wrt quality and if possible i should go for asus. Also i live in a part of the world where warranty claim is not very easy (i just sent my GS 700 that is generating power surges and got it back after three months with a note saying that they cannot reproduce the issue. FML).
AlSo here, for 5$ more i can get a Z97 maximus 7 ranger and for 30+$ Maximus 7 hero, and again, according to the internet, ASUS is the best in quality when it comes to motherboards.
I would like to get your input as to which board should i get from the above or from the following list(except for the last one)
http://www.iamextreme.net/computers/motherboards/intel-1150-z97-chipset-in-pakistan.html
Tbh I'm kinda getting the feeling you WANT to get the Asus ROG mobo ^_^  It all depends on the cash you're willing to spend.
MSI and Asus are both well reputed mobo firms, it's draw of the luck to get a bad mobo from either of them. Their service both has ups and downs and people will always claim one is better than the other.
I can't say much about MSI considering I haven't had such a mobo so I'll leave that up to someone else.
But I'm very fond of my Asus ROG mobo, sure the price was a little higher compared to other mobo's but I was willing to pay that much because of the color scheme I was going for.
Their bios and software is easy to use and the motherboard has a clean and nice look. It's definitly not a wrong decision.
Compiled through certain Tom's Hardware answers and checking the specs: The Hero is a bit better than the Ranger, it has some extra SATA ports and a M- PCIE port. Has extra overclocking software.
Better audio. And a better power source for the microprocessor.
You'll have to decide for yourself if these extra's are worth the extra 30$ for you.
CPU: i7-4770K  Cooler: NZXT X60  GPU: Asus GTX 770 2GB  MB: Asus Maximus VI Hero  RAM: Corsair Vengeance 16GB 1600MHz  PSU: Be Quiet! 630 Watt  Case: NZXT H440
       Storage: 120GB Samsung 840 Evo + 1TB Seagate HDD  KeyboardCorsair K70 RGB  MouseG502 Proteus Spectrum  HeadphoneSennheiser HD598  Mic: Blue Snowball Ice
