When someone calls me on my s5, I can't hear it because it's not loud enough, and yes it is maxed out on volume... Does it matter if I buried it in shallow sand?
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/210900-s5-ringtone-too-quiet/
In today's news, a Galaxy S5 user was fooled by the device's dust protection certification.
"You have got to be the biggest asshole on this forum..."
-GingerbreadPK
sudo rm -rf /
https://linustechtips.com/topic/210900-s5-ringtone-too-quiet/#findComment-2862567
"100% dust resistant"
GG Samsung.
dat xperia life
Honestly Sony disappointed me though. I was so hyped to get the Z3 Compact before it was announced, but turns out its 4.6" rather then the 4.3" of the Z1 Compact that I expected :(
"Rawr XD"
https://linustechtips.com/topic/210900-s5-ringtone-too-quiet/#findComment-2862619
dat xperia life
I had a Motorola Razr M, (4.3") too small.
But 5.2" is a little too big. So I think that 4.6" is a good balance.
5800X3D - RTX 4070 - 2K @ 165Hz
https://linustechtips.com/topic/210900-s5-ringtone-too-quiet/#findComment-2862640
4.6 is the same size as the Xperia T I had... which I guess is okay, but I loved how small the Z1 Compact is
"Rawr XD"
https://linustechtips.com/topic/210900-s5-ringtone-too-quiet/#findComment-2862651
Guys seriously, a solution? I really need help here, could I take out the sand if that's causing the problem?
https://linustechtips.com/topic/210900-s5-ringtone-too-quiet/#findComment-2862892
