I'm assuming you mean the wearable.
are you trying to connect via bluetooth, or wifi?
turn on both just in case. than redo the pair and see if that fixes anything.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/210895-help/#findComment-2862488
Ive been been trying to pair with bluetooth and it doesnt work
hmm, are you using the app that came with it if there was one? it should take a little while to pair.
https://linustechtips.com/topic/210895-help/#findComment-2862541
