weak PSU power connector connection?
Solved by FizzyFantom,
ok, so the problem seems to be that the power cable is too small, and there is a small gap of about 1 mm on both sides of the power cable and PSU, which makes the power cable been able to move freely
should i use some sort of tape, or something to fill up the gap, or do i have to buy a new cable
and yes, im using the power cable that came with the power supply
(ps does every power cable work with every PSU, or do i have to buy a specific power cable, just made for my PSU)
You should look around and see if you have another cable to use. They are standard cables that look like this:
They are used for lots of things so you will probably have another one somewhere ![]()
