You could start provide more information, your case, fans, cooling setup... stuff like that.
This ^^^  and provide your temps because I've seen some people consider "80C" overheating when that temp will not damage anything and the card is fully functional.
https://linustechtips.com/topic/210682-sli-overheating/#findComment-2859451
If the cards have no PCIe slots between them, you can expect higher temperatures on the upper card, as it will have its fan(s) blocked by the card below.
What kind of temperatures are you getting while under load?
My PC:
4670k      GTX 760 ACX      CoolerMaster Hyper 412s      Fractal Design Node 804      G1 Sniper M5      Corsair RM 650      WD Red 1TB     Samsung 840 Evo 120GB
https://linustechtips.com/topic/210682-sli-overheating/#findComment-2859472
I have a corsair 750d with 2 120 mm fans in pull at the front and 1 120mm fan at the back of the case in a push configuration. also i have a h100i at the top of my case with 2 fans on a pull configuratiion and my power supply pulls air from underneath my case
https://linustechtips.com/topic/210682-sli-overheating/#findComment-2859485
i have 1 pci slot between them and most of the time the top card gets up to about 80 - 85 degrees then continues to get hotter and then it crashes
https://linustechtips.com/topic/210682-sli-overheating/#findComment-2859500
set a custom fan profile in msi afterburner so the they don't overheat
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/210682-sli-overheating/#findComment-2859535
80 - 85 degrees is fine for a GPU, possibly something else is causing the crash?
Try to find out the temperature just before it crashes, this would confirm whether it is caused by an overheat.
Do you use MSI afterburner or any similar GPU tuning utility? If so, what are your fan settings? Maybe your fan curve does not allow them to reach 100% speed.
Also an overclocked GPU will generally output more heat, which might be causing this
My PC:
https://linustechtips.com/topic/210682-sli-overheating/#findComment-2859544
i am downloading afterburner now to run a custom fan profile and i will get back to you if it crashes again
https://linustechtips.com/topic/210682-sli-overheating/#findComment-2859559
seems to be fine afterburner is controlling the fans a lot better than them just going at 1 certain rate and then it overheating thanks for the sloution
https://linustechtips.com/topic/210682-sli-overheating/#findComment-2859756
