so... I am going to buy the lg g flex real soon, but i am tempted so much to buy the lg g3 because of the os, but the g flex's style and that display curve just looks amazing.
well since i used iphone only before, i don't really know how android works, but is there any kind of way of hacking the phone, and wipe the lg g flex stock os on there, and up the lg g3 os on the lg g flex.
Thanks :D
Kevin Jin
Linked In
https://linustechtips.com/topic/210548-questions-with-android/
The both use and android and are by LG so they do have the same OS...
My rigs
Desktop CPU: Intel Xeon E5-1680 v2 @ 4.4GHz cooled by a Corsair H105 | Motherboard: Asus Sabertooth X79 | RAM: 32GB G.Skill Sniper DDR3 1600 | GPU: EVGA RTX 3080 SC3 Ultra Gaming | SSD: Samsung 860 EVO 1TB + Crutial M500 240GB + Samsung 840 120GB | HDD: Seagate Barracuda 2TB 7200RPM + WB Black 4TB 7200RPM | Case: Fractal Design Meshify C | Mouse: Logitech G402 & MX Master | Keyboard: Poker II  MX Blue & Leopold 10-key pad Box Royals | Monitor: LG 34UB88-P | Audio: Audio-Technica ATH-M50 + FiiO E5 DAC + Rode NT-USB Mini
Laptop Lenovo Yoga 720 4k Touch
https://linustechtips.com/topic/210548-questions-with-android/#findComment-2857864
Thanks :D
iphones are prision for your mind. there are many ways to "hack" an android devices, you can even choose other roms i like paranoid android. you have options over anything you could ever want right down to the memory
https://linustechtips.com/topic/210548-questions-with-android/#findComment-2857911
android is great (i use and own a nexus 4) but iphones are no prison when jailbreaking is as easy as it is right now.
@Phantomore  -- Just wait a little bit. I wouldnt recommend the gflex SOLELY because it has only a 720p screen, let alone how MASSIVE it is.
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/210548-questions-with-android/#findComment-2857931
well my question is, there are so many different sources of flex2release date, even if its 1080p or even 720p, i would buy its of the flex and just the curv and the design, i just love the g3's software
Kevin Jin
Linked In
https://linustechtips.com/topic/210548-questions-with-android/#findComment-2858067
it is easy but i disagree iphones are a prison even with jail break it still doent offer the same experince as android and the awful hardware inside the iphone holds it back alot
https://linustechtips.com/topic/210548-questions-with-android/#findComment-2924467
