System Slow Shutdown Problems
Go to solution Solved by haurshanked,
If you have the rampage IV black, your board has two bios chips out of the box.  Check your manual for the Bios Switch button and how to use it.  Try setting the same overclock settings on the other bios chip to see if the problem persists.
For your overclock, what is your load line calibration set to, and what is your CPU current capability set to?
i did some testing and found out that its the windows fast startup causing all the trouble. i disabled windows fast startup and it shut down just fine.
now im working on how to solve this problem instead of simply avoiding it, feel free to share some insight ;)
Recently i ran into a very weird problem with my pc. When shut my PC down, my monitors will show the shutting down screen immediately then goes black (i assume that windows has been shut down), but the system (gpu,cpu,fans,psu,etc) is still on, and will stay on for about 30 seconds before it completely shuts off.
to make this problem weirder, restarts are normal, very fast just like before, but shut down is not.
I tried to solve this problem by flashing BIOS to the latest version, drained psu power, unplugged everything then replugged, the problem persists.
Any ideas on how to fix this problem? thanks guys!
  • CPU
    4930K OCed to 4.5hz
  • Motherboard
    Rampage IV Black Edition
  • RAM
    4x4 Corsair Dominator Platinum 1866mhz
  • GPU
    EVGA Titan Black SC (getting another one soon)
  • Case
    Corsair 750D
  • Storage
    2x120gb Corsair Neutron GTX Raid 0, 1x120gb Neutron GTX stand alone, 1x240 Intel 730 SSD,1x2tb WD Black Drive
  • PSU
    Corsair AX860i
  • Display(s)
    BenQ 27' 1080p 144ghz gaming monitor, Samsung U28D590D 4k monitor
  • Cooling
    Corsair H110
  • Keyboard
    Razer Black Widow Ultimate 2014
  • Mouse
    Razer DeathAdder 2013
  • Sound
    Bose Companion 3
  • Operating System
    Windows 8.1
P.S. Going to class now, will check replies later :) thanks again!
https://linustechtips.com/topic/210142-system-slow-shutdown-problems/
I think it could be a BIOS setting. It is just there to cool the PC down before fully shutting down. Or it could be your GPU, some of them have a dust removing feature, it spins the fans in the opposite direction for a short while to remove dust (duh).
EDIT: Just noticed that it was all the fans, GPU's don't decide what system fans do.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
FYI, views don't update until a reply is made. In other words, people can view your thread, but until someone replies, it will always show 0 views.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
Wrong topic?
Wrong topic?
Read the title: "come on guys.... the 0 reply 0 views are making me sad"
What are your OC settings?  (Which parameters did you change)
So your startup is completely normal?  If there is no "Windows did not shut down properly" then the shutdown was completely normal (from the perspective of Windows).  This implies that it's a hardware issue.
Have you tried switching to the other bios chip to see if the problem persists?
Isopropyl alcohol is all you need for cleaning CPU's and motherboard components.  No, you don't need [insert cleaning solution here].  -Source: PhD Student, Chemistry
Why overclockers should understand Load-Line Calibration.
ASUS Rampage IV Black Edition || i7 3930k @ 4.5 GHz || 32 GB Corsair Vengeance CL8 || ASUS GTX 780 DCuII || ASUS Xonar Essence STX || XFX PRO 1000W
I didn't notice that, he edited that in later.
Overclock is fine I'm sure all I changed was the voltages, computer shutdown fine for months this problem just developed recently
No I haven't tried switching bios chips.... I don't have another :(
I'll try that once I get home.
As for the load line calibration and CPU capability is 500 and 120% respectively, I think. Again I have to check to make sure once I get home.
Thanks for the help! I'll get back to you in a few hours :)
Odd how fast startup is affecting shut down... well this isn't something that I know how to fix, maybe someone else can help you  :)
I think you already solved it. If your PC is shutting down properly now then there is nothing wrong.
You cannot solve a problem with a ON/OFF switch, you can merely disable it and that is what you have done.
Fast-startup stores the data currently loaded into the RAM for extra fast loading, start-up programs and possibly some running apps are stored. The reason why you started noticing it later could have been caused by adding start-up programs or having programs running before shutdown. Now that the feature is disable these things should have no affect on shutting down, thus there is no need for further action on the issue.
Unless there still is a second issue that needs to be fixed I would say this thread is solved.
