Okay, I thought people were being overdramatic about heat
Guest
I thought people were being funny or overdramatic about AMD cards and their heat.
But... I added a 3rd monitor and now it's 48-50c idle....
My room, jesus my room, like a sauna over here.
I can't wait until it's winter, no heater needed anymore, my GPU will do the trick.
GPU in sig.
its not just AMD cards.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
Enjoy!
NVIDIA FTW (please dont start a war because of this! IM JUST kiddIng)
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
-Snipe-
Honestly, I still don't get the fuss and my card's an older AMD card.
I say just make a good fan profile on something like MSI Afterburner, that works for me. Mine never goes above 80C on full load, and that's without going above 80% fan speed.
Previously Trogdor8freebird
5800x | Asus x570 Pro Wifi (barely enough for 64GB apparently given it's 2133 and still crashes sometimes) | 64GB DDR4 | 3070 Ti 8GB | Love that whole weeb shit
Yeah I know, but I have a 290 and those are famous for their heat right? :P
I really doubt a third monitor will make your room noticeably hotter.
the difference would be barely measurable, let alone perceivable, unless your room is the size of a closet.
If you're using old non-LED monitors it's probably the monitor itself.
Error: 410
I've only been hearing about AMD problems recently  :(
here in canda thats my CPU and GPU LOAD temp.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
That's probably your airflow.
Well I don't know, it wasn't a problem before,  not too much heat etc. But it is now. I didn't change anything. I do clean regularly. And no cables are in the way either, should have good airflow.
the difference would be barely measurable.
If you're using old non-LCD monitors it's probably the monitor itself.
It's a 144Hz monitor.
Stupid canadia
It's not a problem but more of a WTF moment.
OP's talking about the third monitor increasing his idle GPU temps :P
My Sony TV would noticeably heat up my 8x10 room. By a good 10f
lmao coming from someone in vancouver
please don't talk about winter if you're in Vancouver. because it's hot compared to some places in Canada.
it looks more like he's complaining about the heat in his room.
Idle temps are nothing to bother caring about.
GPU temp doesn't really correlate that well to heat output.
hence the last line of my post, but I meant to say LED.
Error: 410
Well then I am stumped.
I also have a new LED mood-light but that small thing barely puts any heat out.
I don't care about idle temps tbh. I let mine idle at 50-60, but they don't get higher than 80 under load.
Mind you I don't think much of Palit's cooler on them. I will probably go Twin Frozr when I eventually upgrade.
I've lived in calgary for a few years and been around the north pole a few times. xD
Okay I put the fan to 100% a while ago, it's 43 idle now and it seems little bit cooler here in the room.
OIC
You do realise that the GPU is cooler because more of the heat is being moved into your room, right? If anything your room should be slightly warmer.
No, there is a wide open window above and behind the computer. :P
Well that'd be why your room is cooler, not because your GPU fans are at 100% :P
