This build is for a friend in college who is a casual gamer, types alot, and needs it to be portable
PCPartPicker part list: http://pcpartpicker.com/p/NdcCCJ
Price breakdown by merchant: http://pcpartpicker.com/p/NdcCCJ/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($67.99 @ NCIX US)
Its perferct, great OC, and with games and word not taking alot of multithreaded processes, its a great buy
Motherboard: Asus Z97I-PLUS Mini ITX LGA1150 Motherboard  ($159.99 @ Amazon)
HAS WIFI, great stability and its neutral colours
Memory: Corsair Vengeance 8GB (1 x 8GB) DDR3-1866 Memory  ($74.99 @ Newegg)
1 stick for future upgradeability
Storage: Samsung 850 Pro Series 128GB 2.5" Solid State Drive  ($119.00 @ Amazon)
Already has a NAS (8TB, Synology 2bay, 2x4tb WD reds) so this is great for applications and boot :)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  ($129.99 @ Newegg)
Just enough power to play pretty much all the games he wants to play (COD, BF4, Trine 2, Titainfall....ect.)
Case: Cooler Master HAF Stacker 915F Mini ITX Tower Case  ($59.99 @ Newegg)
front mounted psu, great airflow, very small
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($66.66 @ Newegg)
Its a good psu lol
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.99 @ Newegg)
cupholder
Monitor: Acer H236HLbid 60Hz 23.0" Monitor  ($139.99 @ Best Buy)
great monitor, i own one myself
Keyboard: Thermaltake POSEIDON Z Wired Gaming Keyboard  ($69.99 @ Amazon)
linus did a review of it, and its cheap and has blue switches for typing
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($54.99 @ NCIX US)
i also have one and he loves mine
Total: $950.57
Generated by PCPartPicker 2014-09-04 19:57 EDT-0400
https://linustechtips.com/topic/209781-build-for-a-friend/
Motherboard: ASRock Z97E-ITX/ac Mini ITX LGA1150 Motherboard  ($114.99 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Monitor: Samsung S23C570H 23.0" Monitor  ($130.50 @ Newegg)
Total: $869.41
Generated by PCPartPicker 2014-09-04 20:15 EDT-0400
the asrock board is solid and is easy to manage while being like 40$ cheaper so you can save yourself/your friend a little money. and you don't need 650w or gold for something that will pull around 150-200w max probably.
edit again*
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/209781-build-for-a-friend/#findComment-2847305
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($113.98 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Total: $852.49
Generated by PCPartPicker 2014-09-04 20:17 EDT-0400
Put a bigger SSD in and 2X4 GB will usually help a bit better than one stick.
https://linustechtips.com/topic/209781-build-for-a-friend/#findComment-2847315
Motherboard: Asus H97I-PLUS Mini ITX LGA1150 Motherboard  ($107.24 @ Amazon)
Total: $861.66
Generated by PCPartPicker 2014-09-04 20:12 EDT-0400
you can overclock on h97 boards so you can save yourself a little money. and you don't need 650w or gold for something that will pull around 150-200w max probably.
edit realized you need wifi xD stupid me. just the powerspply is changed then.
hmmm how far of an OC though?
https://linustechtips.com/topic/209781-build-for-a-friend/#findComment-2847333
4.2ghz/4.5ghz depending on teh chip but I edited it.
I'm running pretty much the same setting so yeah it's pretty good.
https://linustechtips.com/topic/209781-build-for-a-friend/#findComment-2847371
Stacker 915F for the win!
Seriously a great, compact, super featured mini-ITX case.
My only little question: Does he really need the optical drive? Personally, I'd opt out and mount an HDD up there for more storage :)
Cooler Master USA representing! Looking for help? Head to the CM Fanzone to get in touch with the Customer Support team!
https://linustechtips.com/topic/209781-build-for-a-friend/#findComment-2847632
wow! a CM affiliate! yeah its a great case :)
https://linustechtips.com/topic/209781-build-for-a-friend/#findComment-2862854
