CPU cooler compitability
Go to solution Solved by Rheinwasser,
Gigabyte Z97X-SLI
the NH-D15 will fit in your setup.
I need to replace my stock cooler on my 4790k since I'm going to start overclocking (and massive heatsinks are just dead sexy anyway).
The issue is I'm not sure whether to get a single- or dual-tower heatsink, and I'm not sure which will fit.
I'm considering the Hyper 212 EVO, and the Noctua NH-D14, NH-D15, NH-U12S, NH-U14S.
Firstly, is a dual-tower necessary for overclocking? (I don't wanna go above 4.6, tops.)
If not, is it fine to get the 212 EVO and use 2x Noctua fans? Or do I need to go for the NH-U12S/NH-U14S?
Secondly, will it fit in a Corsair 450D with 2x4GB G.Skill Ripjaws X? (Corsair's site says 165mm maximum, and the NH-D15, NH-U14S are exactly that height. It won't be tapping against the window or anything will it?)
I know that's a lot of questions, thanks for your help though!
My (first) build: i7 4790k | Noctua NH-U14S + NF-A15 | Gigabyte Z97X-SLI | G.Skill Ripjaws X 2x4GB 2133MHz CL9 | Samsung 840 EVO 120GB | Seagate 2TB SSHD | 2x MSI R9 270X TwinFrozr crossfire | Seasonic G Series 750W 80+ Gold | Asus VX238H 23" | GAMDIAS HERMES | Logitech G602 | Steelseries QcK | Windows 8.1
https://linustechtips.com/topic/209690-cpu-cooler-compitability/
which mainboard do you use?
it won't be tapping the window. corsair puts in a little bit of headroom, i am sure.
personally i'd get the U14S.
Edited by Rheinwasser
https://linustechtips.com/topic/209690-cpu-cooler-compitability/#findComment-2845815
Gigabyte Z97X-SLI
Don't look at it from single or dual towers, look at the actual cooling performance from the cooler.
Fair point, my friend.
https://linustechtips.com/topic/209690-cpu-cooler-compitability/#findComment-2845834
what about water cooling using an AIO
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/209690-cpu-cooler-compitability/#findComment-2845851
Because blehhh.
I just like the air cooling aesthetic and old-timey-ness of it better.
But I am fully aware that that's not a good reason :P
That is awesome to know, thank you! I guess I have to decide between the NH-D15 and the U14S now
https://linustechtips.com/topic/209690-cpu-cooler-compitability/#findComment-2845903
Because blehhh.
In terms of air cooling aesthetics, I personally think the D15's bulk looks really aggressive and quite good.
Since it will fit in your case, why not go for the best performing one? The price difference between the two is very small so I don't really see a reason not to go with the D15 unless you prefer the slimmer look of the U14S.
Mainboard ASUS Maximus VII Hero | CPU i5-4690K @ 4.7GHz | RAM Corsair Vengeance Pro 2x4GB | Storage Kingston V300 SSD 240GB & 120GB, WD Black 1TB HDD | GPU EVGA GTX 980 ACX 2.0
PSU EVGA Supernova 850W G2 | Case Phanteks Enthoo Pro | Cooling XSPC Raystorm 750 AX240 watercooling kit / additional 2 x 140mm Bitfenix Spectre Pro Blue LED fans, 1 Cooler Master R4-L2R 120mm fan
https://linustechtips.com/topic/209690-cpu-cooler-compitability/#findComment-2845957
The D15 performs better, but I'm not sure if your ram is compatible, However the u14s is quieter and also performs very well.
If you want as much performance as possible get the D15 just make sure you find out about the RAM height.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/209690-cpu-cooler-compitability/#findComment-2846290
the d15 is much better and also not much more expensive.
disadvantage: you won't see your motherboard anymore.
if you are ok with that, get the d15, otherwise get the u14s.
https://linustechtips.com/topic/209690-cpu-cooler-compitability/#findComment-2850720
