Variable voltage controller
Would something like this work to control fan speed and LED brightness?
http://www.frozencpu.com/products/9091/bus-191/Manual_12V_Variable_Speed_Controller_-_4-Pin_Molex_Connector.html?tl=g6c79s474
... Molex off the PSU into this controller with a molex out into the H440 3 pin fan splitter, which also sends power to the case LEDs, and my Bitfenix Alchemy LEDs.
Would that work?
Whats connected:
The 3 LEDs that come with the case (psu shroud, and two on the IO).
60cm Bitfenix Alchemy LED strip
3 120mm Cougar Vortex PWM
2 Cooler Master Seidon 240m fans
1 140mm H440 stock fan
Alternatively, I could pick up a PWM fan splitter (replacing the built in fan splitter), and an LED splitter so I can add my bitfenix strip to the case LED power button.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/209629-variable-voltage-controller/
Would that work?
Whats connected:
It will control the speed and probably will alter the brightness of the fan LED's, but I doubt it will control the brightness of the LED strip but I'm not 100% sure.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
It will control the speed of the fans but your LED's will always be on as LED's can't be dimmed, they are either on or off.
Well, is there a cheap LED splitter cable so I could connect my LED strip to my H440s other LEDs?
I found an 8-way splitter for only like $6, but I don't really need or want something that big... http://www.frozencpu.com/products/14674/ele-1000/2-Pin_Power_Distribution_PCB_8-Way_Block_MMT-PCB-2-82.html?tl=g6c77s1166 . I just need a two-way splitter--one male to two female.
Is there a better option to control the fans, or no? Not all my fans are PWM so, I'd probably need something to tone down the one 140mm exhaust anyway.
PSU Tier List | CoC
