Case fan compatibality issues
Could there be any? I mean if my stock rear fan is 120mm so all the 120mm fans can fit correctly? And can you plug a 3 pin connector to a 4 pin plug?  Buying a
Cooler Master JetFlo 120
Case - X Predator x1
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
https://linustechtips.com/topic/209105-case-fan-compatibality-issues/
No problems, Yes you can put 3 pin into 4 pin, All the 120mm fans are the same size :)
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
You gotta be careful. Some fans are 120mm but they are in a round shape that the fan itself is 120mm but the mounts might be 140mm.
I can't really remember the specific fan but I have seen this happen where a guy bought a 120mm round fan but the mounting was that of a 140mm fan...
Something like this: CDF-CMR-R4TMBB18FKR0.jpg
If the fan has that "square shape", you only have to consider the width but that should not be a problem.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
I think you have it the other way around.. There are definitely 140mm fans with holes where 120mm fans would have them but I've never seen it the other way around and anyone who would make such a fan is mad.
The fan you linked is just a normal 120mm fan with traditional 120mm fan mounting holes.
I just wanted to give an example... I have heard of fans that say it's size is X and, when you go mount it, it will only mount on a Y slot. I don't know if it's a 120mm that needs a 140mm place or the other way around, just wanted to alarm the guy about the possibility.
