I have this laptop for almost 2 years and I am experiencing some really bad thermal issues with this laptop.
I have sent it for warranty and they said my laptop fan had spoilt..
after repairing, my thermal issue is still there..
ambient temperature is around 27 degrees Celsius.
when idle, it's around 50 degrees Celsius, gaming is around 95 degrees Celsius.
I have the CM laptop cooler (Notepal L1) which doesn't really affect the temperature by much.
it has been really bothering and really concerns me about the problem.
thanks to those to help me in this =)
https://linustechtips.com/topic/20901-n55sf-overheating-issues/
Stock laptop TIM tends to do that after a coupe years :P Just whip on some of this and you should be good to go, you should be able to buy it at any good computer store ;)
If you don't know how to install it here you go:
TIM application on desktops translates pretty well to laptops, I'm sure you get it.
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/20901-n55sf-overheating-issues/#findComment-250753
is it going to be a big difference I got those silver based thermal compound?
https://linustechtips.com/topic/20901-n55sf-overheating-issues/#findComment-250792
