Motion Blur
Go to solution Solved by SteepGnomeKing,
All the way to the left and off you don't want blur on a 120hz monitor. You want a nice crisp image. Plus more fps with it off.
put it to the right to turn the blurr up
New Build:i7 4770k @4.4ghz, Hyper 212 Evo, MSI Z87 GD-65 Gaming, Corsair HX750w, Seagate Barracuda 1TB 7200rpm, Corsair Vengeance 12gb DDR3 1866mhz, EVGA GTX 970 ACX 2.0 SSC
Old build/Little Bros New PC:Intel i5 3570K @4.2ghz, Stock Intel Cooler, Gigabyte z77m-d3h, Capstone 550w, Seagate Barracuda 500gb 5400rpm, Corsair Vengeance 4GB DDR3, EVGA GTX 660 SC R.I.P Tyson 12/22/03- 04/17/13
https://linustechtips.com/topic/20879-motion-blur/#findComment-250065
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
https://linustechtips.com/topic/20879-motion-blur/#findComment-250073
it
Thats what i was thinking..So all the way left..Why would anyone want a blurry image when turning lol?
it actually makes the game look better to me just put it up a bit and itll look nice but put it to your preference i have it at 40% but alternate sometimes depending on the map like firestorm i put it on 20% then rest are pretty much at 40%
https://linustechtips.com/topic/20879-motion-blur/#findComment-250079
it
So when u put in on 20% thats 20% from the left?
https://linustechtips.com/topic/20879-motion-blur/#findComment-250093
20% filled to the right think of it as a loading bar
https://linustechtips.com/topic/20879-motion-blur/#findComment-250100
So from left to right..Got it..Thank you
np man tell me how it looks for you play around with the slider
https://linustechtips.com/topic/20879-motion-blur/#findComment-250168
Turn it off,also you are playing on 120h so i guess you are competitive. Its in the game because on consoles thy use it to hide resoluion and bad textures.
AMD Radeon 7870 Gigabyte OC / Intel i5 3570k / ASrock Z77 Pro4 /Samsung 840 EVO 250GB / WD Blue 500GB 7200rpm / Kingston HyperX T1 2x4GB 1600mhz / SeaSonic 520w M12 / Thermaltake v4 Black
https://linustechtips.com/topic/20879-motion-blur/#findComment-250500
I don't play competitive i just like smoother game play.. I am just OCing my 1440p monitor and playing at 120hz..But i must admit there is such a big difference..Tonight i forget to set to 120hz before a game and monitor was at 60hz..And it was horrible..Don't know how i use to play like that..
https://linustechtips.com/topic/20879-motion-blur/#findComment-250541
when you have you'r Korean monitor 120hz isn't going to make much of a difference because the pixel response time might be low
Don't knock it until you try it..Everyone who says that has never had one..Its as bad a myth as the horrible crossfire stutter in every game..  :D
https://linustechtips.com/topic/20879-motion-blur/#findComment-250551
