 I need a waterblock for this r9 290OC which can be found here http://www.amazon.com/gp/product/B00HS84DFU/ref=ox_sc_sfl_title_2?ie=UTF8&psc=1&smid=A25AIB3D2RT57B
the rest of the build is here http://pcpartpicker.com/p/vCgYRB
I need a waterblock for this card so i can water cool it [duh]
and NO i do not need to get a r9 290x there is less or the same performance in those cards for $200 more
thanks
also if i have some compatibility problems watercooling wise can you point those out?
https://linustechtips.com/topic/208775-gpu-water-block/
