Hey guys. I am building a new rig with an ATX board. The budget it 70€ for the case. Which cas whould you recomend?(needs to have room for hyper evo and for gigabyte gtx 770)
My other question is, is the Evo good for overclocking my cpu?(i7 4790k) How much will I be able to overclock it with th Evo?
Thanks in advance.
https://linustechtips.com/topic/208148-hyper-212-evo-and-case/
Corsair Carbide 300R for the case and the 212 EVO is a good cooler, depending on the quality of your CPU ou should be abled to reach 4.2 GHz easily
While talking about Hyper 212, will it be great with the stock fan (like raw not adding anythink, just putting it on CPU?
https://linustechtips.com/topic/208148-hyper-212-evo-and-case/#findComment-2823928
The stock fan is good. Nothing special but robust and performs good.
i have that case 8)
Is it good? :) It just happens to lie in that price range so i suggested it. :)
who cares...
https://linustechtips.com/topic/208148-hyper-212-evo-and-case/#findComment-2824003
200R or 300R
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/208148-hyper-212-evo-and-case/#findComment-2824018
yea i love it, easy to work with and nice cable management options. looks really clean, the fans it comes with are quiet. only thing i wish it came with was a dust cover for the top
https://linustechtips.com/topic/208148-hyper-212-evo-and-case/#findComment-2824360
It's great, cools down quite a bit and has been used with OC'ed CPUs with the "stock" fan and thermal paste.
The included fan, however, can be noisy at high RPM, many reviews/benchmarks point that out.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/208148-hyper-212-evo-and-case/#findComment-2831058
